chart plotter in use
Balticfly
Active Member
29 Sep 2016
I single-hand on long passages and have only recently installed a chart plotter, an eS75 MFD. I want to add an AIS and run this through the chart plotter. I need to navigate from the chart table as well as steer at the helm.
I either:
• need a cockpit repeater so that I keep the plotter at the chart table and work with it there but see its output when at the helm
• or mount the plotter in the cockpit but also be able to see its output and drive it from chart table.
Can I use a tablet at the chart table to read the chart plotter output AND enter new waypoints and look at routes and so on? Will the AIS data showing on the chart plotter also show on the tablet or do I need a spate connection from AIS to tablet?
Can I use an ST60 tridata display in the cockpit as repeater? Will this show the AIS data via the plotter or will it need a separate feed from the AIS? Or will it not show AIS at all?
What alternative repeater displays could I mount in the cockpit?
Thanks for any help.
