nicclark
I'm hoping that the collective expertise might suggest a solution to my alternator and charging issues!
We've an Ocean 37, twin modern internal regulated alternators have replaced the CAV versions that were fitted. There are two battery banks - one charged by the starboard engine for starting, and the other charged by the port for domestics.
The ammeters are original and are in the high current circuit, so very large cable goes to the helm - not sure if there is a better way to do this now.
The main issue is that the newest alternator does not charge well - it's intermittent at best and I am not sure if it has been damaged by being at low speeds on the river, which is the second issue - I don't think it spins fast enough to cut in so charging is not taking place.
Both battery lights stay on when the engines run.
One Tacho, for the older and more reliable alternator, works well but the other doesn't work, or jumps a bit when a lot of throttle is applied.
Essentially, I'd like to build a reliable charging system that works at relatively low speeds and doesn't cost the earth and I am not sure where to start!
I like the look of the alternator to battery charger, but they are really expensive for our 24v system, and I don't think they would solve the speed issue.
Any ideas or experience appreciated!
