nickfabbri
The alternator on my Yanmar 3GM20 is rated at 60 A. Am I being a moron in assuming that it charges the batteries at 60 Amps per hour?If so can someone please enlighten me.
Many thanks
Many thanks
Many thanks
Not a moron! Well no. If you fit a sterling or similar advanced regulator then you will get max amps (60 in your case) until the batteries are 90% full. It will also take your batteries up to 14.7volts for a while which will prevent and or remove sulphation from the plates. My advice, as a livaboard with 2,000ah of batteries, is fit one now! I have on all of my boats over the last 20 years.if your total battery bank capacity was in the region of 240Ah and your bank was 50% delpeted, then perhaps your alternator could deliver close to 60A initially. but not for long.
The alternators current output will depend on the "charge acceptance rate" of your battery bank. The charge acceptance rate will depend on the current state of charge of the battery. The rule of thumb I use - maximum alternator output = 50% of discharged capacity.
So a fully charged bank that has given up 20Ah may accept 10amps initially upon charging. as the battery's state of charge increases, the charge acceptance rate will reduce accordingly - to a first approximation.
worth a search as there are loads of posts here on battery charging.
