pcatterall
I notice that my toothbrush charger charges through a sealed plastic conector ( IE no metal contacts. How does this work and is there a marine use which we could take advantage of or is it inefficient?
The toothbrush charging system works without metal to metal contact but is on 240 volts. If we were to use the same principle to charge other items on the boat - a torch for example - it would need to work on 12 volts. But would 12 v be enough?
Missed the point. Nothing to do with tranformers. The question is whether a 12 v boat system can charge a 12 v device using the no metal to metal technology?
