gfbalduc
Time has come, in my long preparation efforts, to replace my 6-years old batteries, which last summer showed they were discharging much too fast! /forums/images/graemlins/frown.gif
What I have now is what look like 4 identical 95Ah "maintenance-free" sealed batteries, one for starting and the remaining 3 for services.
The batteries are an almost snug fit into an aluminium coffer, so I'm pretty much limited to whatever I can fit in this space.
Replacing same-for-same is obviously the first option, not exceedingly expensive and probably I can even get a few more Ah from modern batteries of the same size.
The more sophisticated alternative could be to go for GEL batteries for services, plus one battery suitable for engine starting.
Now, a problem springs to mind: GEL batteries have a different charging cycle, and a different floating voltage than most other technologies.
I have several chargers/regulators on board (engine, shore-power, solar panels, windgen, you-name-it...), but although some of them can be configured for the specific battery technology and have separate outputs for the two banks, none of them would accept two different technologies in the two banks.
Is there any way around it? Would setting the chargers for the most sensitive batteries be acceptable for the others, or would I end up with one bank being systematically under-charged?
Any alternative combination (like traction batteries i/o Gel for services) that would work out better? /forums/images/graemlins/confused.gif
Thanks for all inputs/experiences
