Charging from a car
JohnK
10 Jun 2004
Hi all,
I remember reading that some people with boats on trailers use the second power socket on the tow hitch to charge the battery when towing the boat.
Does anyone know how to wire this up, is it simply a connection straight to the battery?
TIA,
John
brianrunyard
30 May 2001
Poole, Dorset. UK
homepage.ntlworld.com
Need a split charge relay or blocking diode, otherwise when you start the car engine, it will try to draw current from both batteries and the cable going to the second one isn't heavy enough to take the current, at best will burn out the cable at worst will cause a fire.
