ffiill
There have been various recent threads re.solid fuel heaters.I recently made a drip fed diesel heater but it had a tendancy to misbehave so I decided to try out a charcoal heater.
It loosly follows the dimensions of the Pansy heater with the grate a little over 1/3 of the way up the tube.
The main tube is 4" dia.stainless exhaust tube about 16" long with the grate being a slightly ground down 4" cast iron round gulley drain cover.The chimney is on the side as it has to fit a specific enclosed space.The top and bottom lids are sections of 4 1/2" exhaust tube with a plate welded to it.
The lids are held down against a fire rope seal with a couple of lengths of stainless M6 studding and wing nuts.
If I had had an open space to install it in I would have left the main tube at its bought length of 500mm/20" and created a deeper bottom pan to collect the ash.
The main criteria determining its dimensions are size of grates available and similarly the size of stainless exhaust tube-both readily available on e bay.
The pic shows it with a temporary chimney and running half full of charcoal briquettes.
Its very hot and shows no signs of any leaks!
