Ok didnt realise you were a regular boating visitor to the Channel Islands. Seeing as you are I will bow down to your superior knoweldge on this one. /forums/images/graemlins/wink.gif
I've try hard to find the right procedure to publish photos!!!.. I hope it will work?? lets hope..
The hook is made in a stainless steel plate of 10 mm thickness.. all dimensions are in mm.
- The main line will be attached with a 10 mm shackle (in the 11 mm hole)
- the small hole in the opposite corner is used for a small trip line.. Whith a small line attached to this hole, when your chain is under tension, just release the main line and you can easily remove the hook..
I will send you the drawing and the photo.
I hope it will work.. I've try hard to find the right procedure to publish photos... /forums/images/graemlins/confused.gif
First the "iron hand" from Wichard:
Then the hook I did manufacture and that i'm using aboard Hylas:
and now the drawing:
The hook is manufactured using a stainless steel plate of 10 mm thickness.. all dimensions are in mm.
- The main line is attached to the biggest hole (11 mm)
- The small hole on the opposite corner is used to attach a trip line:
With you chain tight, release the main line and pull the small trip line, the hook will desengage itself free..
