channel island 22
david2509
New Member
17 Dec 2011
hi all,i have just bought the above boat for £2500 its got a perkins 4108 with a volvo 270 out leg,i am looking to change the engine,i struggle to get 7kts out of it,what would be the best engine to get for it?
That's a heavily modified CI22, the wheelhouse is not original and none were built with outdrives. However it's a great hull, I had one for 9 years and loved it.
I doubt anyone will be able to answer your question because of the alterations.
That is its displacement hull speed. To get it to go significantly faster would need a massive increase in power - probably up to 120hp. Normally that hull is fitted with shaft drive engines around 40-50hp for displacement and 100+ for planing - just.
Uneconomic to re- engine. Unlikely to find a decent SH engine that would link directly to the outdrive, and new would be 5 times or more than you paid for the boat.
Enjoy it as it is, it should sip fuel at 5 knots. If you did switch to a much bigger engine to go significantly faster than hull displacement speed you'd also spend a fortune on fuel...
Inclind to agree but you could talk about marinizing something from a ford or similiar with the chap at lancing marine. Has been very helpful when I have phoned and asked questions.
do you have anu pics of thr ci22 you had so i can see the difference please thanks
If it has an outdrive I would presume the engine will be at the back, a more powerful one (you would need maybe 120-150bhp) might be too heavy.
