kalanka
I am replacing an ancient Navico depth sounder with a Clipper Duet (combined log and sounder) . The previous owner installed the log section and display of the Duet but did not install the supplied Clipper transducer.
Ought to be a simple replacement and plug in job but the new transducer is 36 mm in diameter and the plastic housing that holds the old tranducer (and screws on to the through hull fitting) is only 40 mm - leaving very little material to hold the new tranducer if I bore out the old one.
I understand I can't epoxy direct to the hull because it is foam cored.
Has anyone any ideas? Might there be a tailor made adaptor?
