annageek
So we've been in the market for a new prop for a while now, and have done nothing about it, other than ask for people's opinions. Nevertheless, it's bit the bullet time and sort it out.
At present, we have a 19" pitch Mercury High 5 (5 blade, stainless steel) prop. At WOT, on our Mercruiser 3.0L, we hit about 4750rpm (spot on for that engine). We cruise at about 3300-3400rpm which gives us about 22-23kts which just 'feel' like the boat's sweet spot.
We're planning to get a 19" Mercury Vengeance (3 blade, stainless steel) prop. I am hoping that this will maintain about 4700-4800rpm at WOT. I am also hoping this will enable us to cruise at about 3200rpm (more efficient thn 3300-3400rpm).
I believe that with the High 5, the rule of thumb of knocking off an inch of pitch for every extra blade does not apply. I read somewhere that the High 5 blade design is quite specific to watersports (slippier than it should be for better hole shot) and doesn't therefore follow this rule. Is this correct?
Two things have changed since we last ran on the High 5:
1. This winter, We removed the years of old, crusty antifoul paint off the bottom (since we're dry stacked - and loving it) and now have a smooth, shiny, more hydrodynamic bottom - gotta love a hydronamic bottom
2. We have an exra 80L of fuel capacity on board (180L vs 100L previously).
My feeling is that the increase in maximum fuel load combined with the slight improvement in hydrodynamicy will, roughly speaking cancel out. Thoughs on this theory are welcomed!
The reason we want to change is to improve efficiency at cruising speeds. This is NOT to provide a financial benefit (with the cost of the prop, this'll never come near to making financial sense - we know that!), but to improve crusing range (a bit). If we could improve range at cruise by 10-20%, that'd be worthwhile for us.
We never do watersports (but would keep the High 5 incase we did / incase the next owner wants to / as a spare prop). We're based in the Solent, and therefore regularly have to tackle the 'Solent chop'. Will we likely notice much difference with a 3-blade prop, as I understand 5-bladers are supposed to have better grip and can therefore handle a bit better in confused waters like those found in t'Solent?
FWIW, the reason I'm looking at the 19" Vengeance is I remember reading on here that oGaryo, when he had his Fletcher 19gts with 3.0L Merc fitted the same. Naturally, I will be PMing him shortly to kindly seek his opinion
Sense check please? Am I expecting too much? Am I missing anything?
Thanks!!
Anna.
Thanks!!
Anna.
