ChiPete
Hi all,
I've got a Morer Navtax unit which I'm very please with it given it's size and portability. The one issue I have with it is the reception, or rather, lack of. So! Now it's out of warranty, I plan to make a mod and replace the internal ferrite rod with an external omnidirectional antenna.
I've sourced the tuned 490-518Mhz passive antenna from ICS Electronics - very fair price including a pushpit mount and just around the corner from me. I plan to fit a BNC connector to the unit to connect the antenna and ground the co-axial cable shielding to an anode.
There are, of course, two ends to the ferrite coil, let's call them ''A'' and ''B''. Each end is soldered to the PCB at different points - makes sense. When I fit the new antenna, there'll only be one conductor - can anyone (perhaps any radio hams out there who got past the ''Propagation & Antennas'' chapter) give me any pointers as to which end of the coil I should connect the one conductor - ''A'', ''B'', both...?
Cheers,
Cheers,
