[2574]
How often do you change your freshwater engine coolant (with 50% antifreeze mix)? Every year? How do you dispose of the old coolant? Not safe to pump overboard so do you pump out and dispose ashore?
It could be argued that putting a toxic, but pleasant tasting, liquid into a soft drinks bottle was a foolish and dangerous thing to do.i was hoping this year to put the tube from my SEAGO oil extractor over the drain nipple and simply suck out the old antifreeze. unfortunately as other posts detail, the elbow was bunged up so i had to poke a wire down and the antifreeze ran into the engine compartment as normal. however, the SEAGO pump sucked it all up and then decanting it into an old plastic soft drinks bottle was the easy way to dispose of it.
the French did it & with a cork too![]()
Its a bit like the changing brake fluid in a car bit - never needed in the old days but now with all the modern materials and technology they try to tell you to do it every couple of years.
Last changed my Volvo Penta MD2030 at 5 years. One of the messiest jobs to do. Not a hope in hell of collecting the deluge, once it comes. Simply mop-up the bilge with old towels into a bucket. Then, dispose of ashore.
Not sure if there's an elloquent way to do it. I'll watch with interest.
On my 2040 the coolant drain has a small tap/valve on the engine block. On the outlet-side it has a small nozzle about 5-6mm in diameter.
Interesting point BH but my recollection is that 40 years I also would never change brake fluid. However, I did have to change slave cylinder seals, pistons or complete units fairly regularly.
About 20 years ago I read that cylinder deterioration was cause by water being absorbed into the fluid so I started to change the fluid on all my cars and bikes every 3 or 4 years. I have not replaced a single seal, piston or cylinder in the last 20 years.
Richard
