bluedragon
I've just bought a chain stopper from Jimmy Green to act as a ratchet when hauling in the chain by hand.
The problem is I don't see how this is going to work with the angle of pull involved. When used with a horizontal pull (such as from a windlass) the function is clear and it will take the chain load on the flap once the pulling tension is released. But with manual hauling in the standing position, the angle from the bow roller to pulling position will be some 25-45 degrees from the horizontal. If I feed the chain under the flap, the pull angle will apply from there and potentially create a lot of friction and possibly jam. Have I missed the point here somewhere? Do others use these devices for hand-hauling chain? Where do you fit them and how do you use them?
