Ok .... here we have a reasonable Centaur with rebedded bilge keels. The silly little transverse stringer fillets fitted to the keel area have delaminated and 'another' surveyor has also recc'd glassing in extra bigger transverse stringers to take grounding loads on a tidal berth......... (Note I do not disagree with him - its another guys boat anyway - but have also other ways to do it etc.)
I have a few ways to strengthen the keel areas - having inspected enough over years to see others ways of doing it.
a) Remove nuts and protect threads - while glassing in heavy matt that is spread longitudinally and transverse easing out to sides to spread load. Set and use larger stainless steel bearing washers etc. to wind nuts onto.
b) Fashion a stainless steel long plate to fit - passing through any stiffeners - the keel bed and wind nuts onto that.
c) GRP rope and matt used in a ctas cradle to increase GRP around all nuts and keel area.
Now for the Centaur owners and others out there - lets hear your solution to it .......
For those not aware - this is a common item on Westerlies ... and immense experience is out there - with some traditional and not so traditional solutions !
<hr width=100% size=1>Nigel ... and of course Yahoo groups :
http://groups.yahoo.com/group/gps-navigator/
