jellylegs
I have a very slight weeping keel bolt do i just tighten the nut?
Centaurs are designed to sit happily on hard ground, it is deep soft mud that can cause problems, with suction causing lateral flexing of the keels as she sinks in & pulls out on each tide.
I plan to have the work done in the winter. Estimated 2k to do both sides. Remove the keel, strengthen the stub, replace the bolts, and re bed. Ta.
How did you lift your boat to drop the keel?
What, ten messages on keel bolts, and nobody has mentioned Bavarias? Perhaps you guys are starting to mellow a little![]()
