Geoffs
I have well over 500hrs on my D4/260 - DPH outfit, and all has been faultless.
In the last 10hrs, or so, I have been seeing what I think is cavitation pitting on all blades.
The boat is dry berthed, so I don't think it is corrosion, and I check all running gear after each use, so I know this has only appeared in the las 10hrs. It is on the forward surface of the blades, so can only be cavitation, I think.
I polished lightly with wet 'n dry to show up in photo.
The question is, why should I start seeing this so suddenly after 500hrs? Nothing has changed in boat loading or trim. Bottom is totally clean and polished, no antifoul, even. There's no sign of any slipping or ventilation when running. It doesn't get hard use, 2500rpm and 23 knots is the norm, and performance is normal. No tight high speed turns or hard acceleration.
My local VP dealer has been to have a look, and checked boat geometry, cavitation plate level with bottom of boat etc., but they have no answers.
I know that some have experienced corrosion on G series Nickel/Ali/Bronze props, but I don't think that's my problem.
Any ideas what can cause this, and remedial action? Are there any known cavitation issues with G series props, any one experienced this sudden activity? I'll drop a line to VP, but don't expect a very encouraging response.
