Babylon
I have a traditional metal-bodied CAV fuel filter which takes the Delphi 296 filter, and which has a plastic screw-in drain plug on the bottom. A couple of questions or so:
Are these units 'handed' - ie can I move it from the port side of the engine bay to the stbd side?
If I do move it to the stbd side (that's where the fuel intake is located on the new Beta engine) and have to replace it with the correctly-handed one, can I fit a version with a glass bowl so I can see if there's any water in the fuel? The one I'm looking at is http://www.dieselpartsdirect.co.uk/...on/Agglomerators/5836B325-Delphi-Agglomerator however this seems to have a much shallower glass bowl compared to the all-metal one.
Is the glass bowl safe?
Finally, the 296 replacement filter comes with two large circular seals (obvious where these fit) and a very small circular seal (not obvious where this goes). What's the small one for?
