bluerm166
This has been retired because of external corrosion but used for an occasional 'polishing' rig,where it filters and passes diesel with about 400 mm head of feed.
Can anyone familiar with these explain why it is barely possible to blow or suck air through the inlet (which from the embossed arrow appears either lower spigot) .It seems the priming diapragm causes this reduction in flow.
In use on the boat the filter works well enough,but is it imposing an excess load on the engine pump ?
This anomaly is very apparent if you compare an 'original' CAV body - so no primer - where,as you would expect, there is absolutely no resistance to air blown through either spigot.
Yes,I am going to fit an inline bulb with a plain body .
