JRMacGregor
Caulking - \"walking\" or shaking out
Hello Folks,
Do any members have experience or opinion on the possibility of excessive engine vibration causing the caulking to "walk" on an old boat.
I have an old sailing fishing boat (14t displacement, 38ft) which is fitted with a large, slow revving engine (44hp, 4 cylinder, 6 litre, idle 250rpm, max rpm 1000). The engine runs well, but its basic characteristics and the fact that the engine feet are located low on the crankcase means that there is obvious transverse "rocking" when starting and stopping.
The boat was originally built in 1911 without an engine, but is reasonably stoutly built (ex Scottish fishing vessel) with doubled sawn oak frames.
The boat has been repaired, refastened and recaulked at various times over the years (most recently in 2003), but I suspect that she leaks more after the engine has been run. I worry that this might be a cumulative and irreversible process. You can feel (and see, in calm water) the boat's hull vibrating.
In my heart I feel that a smaller, lighter, faster running modern diesel would be easier on the boat, but the engine (a Kelvin J4) is a bit of a classic in its own right, and I am reluctant to remove it.
Kelvin J4's WERE fitted in some smaller, but more modern Scottish MFVs, and are perfectly at home in larger and more heavily built vessels. However, my boat (a Loch Fyne skiff) is not as heavily built as a modern MFV or even an East Coast herring lugger.
Any opinions gratefully received.
James MacGregor
Hello Folks,
James MacGregor
