Whitelighter
What speed will a decent sized modern cat really sail at - one in the 40ft range for example.
I am used to monohulls and I guess a good cruising boat of that length with easily do 6-7knts with 8knts if you are on the limit. Will a cat do much more and if so by how much? Would a 40ft cat easily hit 10 knts for example?
I assume that a big crusing cat will rarely (if ever) lift a hull, but what are they like a different points of sailing? do they point well or do you basically have to keep everything on the beam/astern?
Also, is it hard to find berths in the UK or is that all a bit of hype.
Cheers
Jez
Cheers
Jez
