thefatlady
I have just come across another boat with this problem on both engines, so in case more owners are not aware, this is what it is about:
The CAT 3208 aftercooler seawater flanges are (were) made of aluminium. They rot. If they go, there is a very strong likelihood of getting sea water in the intake and wrecking the engine. The aluminium flanges have been superseded by bronze ones.
I am told that a lot of engines have been wrecked and that Caterpillar recognise the problem, They did a "recall" but could not contact many owners. I am also told that they have been known, under pressure, to replace the flanges free.
The first sign is tell-tale black streaking on the flange as below. A boatyard may tell you that the whole aftercooler must be removed to replace the flanges, but it can be done in-situ.
This is a good engine with a minor design fault which could become serious if left. You have been warned.
