BOATKID
will castrol GTX Diesel oil be okay for 20 year old cummins 4BT turbo engines
The quoted manual does not refer to ACEA specifications so please explain two things:Castrol GTX is ACEA A3/B3, thefore totally unsuitable, besides being incorrect viscosity
And the link to what the manufacturer currently prints in black and white for that engine is ???????Why bugger about best guessing what you think may work when the manufacturer prints requirement in black and white. It really is as simple as that.
It is unlikely that any oil meeting this standard will preclude its use in a Cummins engine due to its inability to cope with top ring temperatures, leading to rapid bore wearUnfortunately I had to drop Metalwork for Latin, but am lost in the semantics of how many double negatives are needed to make the point of what oil I should use. Or avoid.
