A
Alcyone
Our commodore has just informed us of the restrictions on the club Forum:
Owing to exceptionally low river flows into the Bay, the Harbour Authority is required to implement locking restrictions for vessels in order to maintain the Bay level within the statutory limits.
Effective immediately, and continuing until significant rainfall increases river flows, the following locking times will be in place:
0001 Mon – 0600 Fri:
Outbound - 1 lock per hour (on the hour)
Inbound - 1 lock per hour (45 mins past the hour)
0600 Fri – 2359 Sun:
Outbound - 1 lock per half hour (on the hour and 30 mins past the hour)
Inbound - 1 lock per half hour (15 mins and 45 mins past the hour)
Mariners should note that delays are likely both locking in and locking out, particularly at weekends and other busy periods. It is therefore advisable to use non-peak locking times whenever possible.
The situation with regard to the maintenance of the Bay level will be kept under constant review, and restrictions will be relaxed if at all possible. However, it should also be noted that, given the forecast for continuing dry weather, there may be a necessity to further restrict locking operations to ensure the statutory Bay level is maintained.
Up to date information may be obtained from Barrage Control on 029 2070 0234 or on VHF Channel 18. Where delays do occur, mariners are requested to exercise patience and act in accordance with the locking instructions given to them by Barrage staff.
We are evidently only getting around half the flow we normally get from rivers, with no end in sight to the dry sepll. Evidently there will be a queueing system for locks, with patrol boats watching for queue jumpers!
