Carbon fibre foam core dinghy.
burgundyben
28 Nov 2002
Niton Radio
I have a Fairey Duckling dinghy, it suits our purpose very well, except, as light as it is, even lighter would be better.
Could I use it to make a mould, then build a carbon and foam core lighter weight version?
Or perhaps not need foam core? Just carbon and bucket and brush laminate?
9' 6" long and 4' wide, how light could it be?
Carbon is not ideal as a tender material. I've worked a lot with carbon in development class dinghy circles, and it has poor resistance to puncture type loads. Run it up a slipway, have a stone in your shoe, drop something on it and it will be bad news all round.
The majority of the weight in your layup will be resin. And unless you are going to get all peel ply/vac bag about things you're kinda wasting your time with expensive carbon. And if you are building a light carbon dinghy, that you're not expecting to take the rough and tumble of life as a tender, why not build something better than a Fairy duckling?
Our 12’5” nesting dinghy weighs 54kg. It is made from polyester with carbon stregthening to transom, daggerboard case and stringers. The locker and bouyancy compartments and bulkheads where it nests are all foam core panels. Ours is built strong as we use a 15hp engine but you could build lighter for a smaller hp engine and save weight in floor stringers and transom layup
It has to be a Fairey because it does. I only have Fairey boats. I have a Duckling, so that can be my mould.
I was thinking it would be an infused vac bag job.
The duckling is 9' 6" and is 3 layers of hot moulded veneer, its 45kg.
ideally i'd like to halve that.
Nestaway boats do a "carbon-fibre" lightweight version of their gorgeous skiffs but I believe they put some Kevlar in as well though, which is common in this sort of use case. Although strong carbon fibre is very stiff and brittle, whilst Kevlar is not at all stiff but is very resistant to punctures and tears (hence flak jackets, motorcycle gear, etc.). Would be absolutely pointless doing it unless you did go vacuum/pre-preg though. 22.5kg is a VERY aggressive target. 45kg isn't shabby to start for a fitted 9' 6" dinghy to start with. In Aerospace you can usually get away with just carbon and even then you won't see a 50% saving over grp.
Ah, it's the first bit of this post that's important then. To keep the weight down and functionality and durability right up there is where careful design comes in. My friend's old Int. Moth weighed 34kg and was 11' LOA but that's not the sort of dinghy you're looking for. You seem keen on a feather-light high tech Fairey Duckling.
Depending on where in the country you are there must be a local boat building co that can assist with building a plug and a first off moulding in carbon/Kevlar but it will be an exercise in spending money. You will get the high tech materials and overall design but remember that the design of the dinghy is for wood construction: you won't get all of the benefits of your expenditure on carbon and Kevlar.
To give you some idea, a 12' Cherub popping off the plug before bulkheads, deck and fitout is about 10kg. Min weight for a fully finished, fitted and painted hull is 50kg but most will be carrying a few kg of lead as correctors. A fully fitted Fireball at 16' is 70kg (minus foils, rig, ropes).
22kg is pretty aggressive but not impossible. However don't forget "strong, light, cheap. Pick two".
This does seem like an amazing way to burn cash for little benefit. I'd recommend that you start pricing up the cost of weave and resin to make the boat, plus the effort and materials to make the mould and decide if it's worth it for a marginal weight saving. You'd also be hard pressed to find a worse shape to try and make in a female mould with a foam core.
The American Dyer Dhow is of a similar size and shape to the Fairey Duckling. The rowing only version in single skin grp with teak seats and bronze fittings weighs less than 45kg. I think with glass/foam seats you could get it nearer 40kg. Less than that and you've got to re-engineer.
However a complete foam sandwich in any material is not the way to go as the 'skins' become too thin and fragile. By the time you've made the outer skin robust enough, it's rugged enough to be a single skin. Better to think of a single skin structure with just sufficient ribs and stingers (seat support / bow and stern buoyancy) and gunwale structure to give it rigidity.
Your current dinghy would make an ideal plug and is probably curvaceous enough to only need a one piece mould. Sometimes making the transom removable helps extraction. The 'flat' moulds for the thwart and seats are easy to make in mdf.
The good thing about using internal 'stiffeners' is that you can 'engineer' them in the light of experience. I would start with adding an in and out whale in 12mm x 25mm cedar, the central thwart rigidily attached to both sides and a rear seat / buoyancy 'tank'. Then see how it goes. You could then add short foam stringers or a support from the underside of the thwart to keel, etc, if necessary.
Excellent project.
If you want truly light weigh, maybe consider a skin on frame design.
If rigid shape+space were not an issue, that would be my choice.
Edit:
Unless professionally calculated, adding carbon fiber to fiberglass is usually pointless.
Carbon fiber has no stretch and will be broken long before the glass has stretched enough to start breaking.
Great inputs. Thank you.
You see, not only will it be an interesting project for me and my boy, a lighter dinghy will be easier to handle, it would be fab if I could get it to the point where I can lift it onto my roof rack on my own, then lift it off, walk to waters edge and plop it in.
Also, in time, I'll be wanting to hoist it aboard using davits, the lighter the dinghy is the lighter the davit can be.
A mould for a Duckling was on sale for ages on eBay. I wonder if it's still around.
I remember that. It wasn't a grp mould, it was a wooden buck for making a wooden one. I wasn't convinced at the time that it was a Fairey built buck (no reason that it has to be). Its an Uffa Fox design and the plans are available.
Seems to be the easiest way forward is to use mine as a plug to make a mould.
...Seems to be the easiest way forward is to use mine as a plug to make a mould.
An even easier way would be to use your existing boat as a male form and lay up your foam and composite outer skin on top of it then demould and lay up the inner skin.
Whatever you do it wouod be great to see a build thread on here...
Boo2
One thing to consider if you make the dinghy super light as you propose. It will likely feel more tippy and it will be more effected by the wind. A friend of mine is a proffessional boat builder has made hundereds of small boats. He made his tender from carbon and core for stiffness and lightweight but regretted it and said the previous version of the same boat being standard polyester and carbon stiffening where needed was a better boat. Less tippy.
Carbon is great for stiffness but not good for puncture resistance. Kevlar can be hard to work with and only gives a small increase in strength over standard E glass. Seems like a lot of expense and effort for little gain.
You have to take into account that I'm an 18 stone fat bastard!
Are you wedded to building a Fairey copy? If not, and weight is the most important factor, it's hard to beat 4mm marine ply for strength and lightness. The tender I've just built is a Woods Designs Duo which is 3m (10ft) long and weighs 26kg. It's fairly narrow as I wanted something that would row and tow efficiently, but it's standard stitch-and-glue construction and a similar wider design wouldn't increase the weight much. That weight includes a glass/epoxy layer on the bottom inside and out, several layers of glass tape on the chines with an extra couple of coats of graphite thickened epoxy for protection, and kevlar tape just at the front corners where it's likely to get rammed into the beach or slipway. Also several stiffening pieces underneath with PVC wear strips to protect the bottom from abrasion. Although it sounds very thin, 4mm ply is plenty strong enough and it's going to be hard to make anything as light even using carbon.
That's an interesting thought - wonder what a cold-moulded 10' tender would weigh using modern resins, etc. Another option if you want to stay authentic, aviation and of that era is a Grumman aloominum dinghy. Dunno how much they weigh but it can't be a lot, not exactly British but then it doesn't pretend to be in any way. https://www.shoppok.com/poconos/a,2...-Sailing-Dinghy----500--East-Stroudsburg-.htm
I did have a brief look online at aloooominum dinghies, they seem heavier than what I am aiming for, and not a Fairey, although, it did cross my mind to buy a tig welder and make an aloooooominum Duckling.
