Can't Get Revs Above 700rpm on Volvo Penta 2002
RSchute
2 May 2023
Hi All, Upon launching my boat, I'm able to start my Volvo Penta 2002 engine but I can't get the revs up beyond 700rpm with full throttle.
Fuel appears to be getting everywhere it is supposed to get to and I had the engine running for 45+ minutes but only at low RPM and on 2 occasions it went to about 2000RPM but quickly settled down to 700RPM.
A few things to note:
- I observed a good healthy stream of fuel coming from the bleed screw, the injectors and injector pumps when the nuts were cracked open.
- The lever attached to the fuel regulation system is moving the full range when the throttle is in idle to it's maximum throttle position.
- Fresh diesel is being run directly to the lift pump.
- Both injectors were replaced 2 years ago.
- The engine sounds okay at 700rpm
Does anyone have any ideas on why I can't get beyond 700 under full throttle?
jamie N
20 Dec 2012
Fortrose
Welcome to the forum.
Would it be that the lever has become disconnected from the actuator 'inside' the body, such as a loosened grub screw?
I don't know your engine at all, but that's the thought that I had.
ithet
27 Mar 2009
UK, Hamble
Sounds possibly like that bloody bleed screw on the filter. See other recent thread about fitting a helicoil. When I had an issue the engine actually ran better with it sightly loosened and letting out fuel (I think when I tried to tighten it stopped fuel coming out, but air got in).
Refueler
13 Sep 2008
Far away from hooray henrys
May sound daft - but I had similar happen with my Perkins ... but it was not the engine or fuel system at fault. I have a single lever control for throttle and direction. The pawl connection sheered and the lever moved back and forth - gears worked - but throttle didn't move ...
All looked good ... I moved pump throttle by hand engine acted as it should ... but when handle moved ... nothing. but of course being alone - I couyld not see both engine and handle same time. It was only when I removed control from mounting - I then saw the broken arm
Pal of mine who may make my Arch made a Dural copy for 5 euros .... magic !!
I even gave the whole unit a birthday :
Before ...
After ....
