VicS
If a vessel gives a sound (or light) signal to indicate an intended manoeuvre but then does not carry out the manoeuvre for some reason how would you expect them to cancel that signal
I would expect a new signal to countermand the old, but I have no idea if this is correct.
All agreed. Though sadly a quick toot 0.2 seconds might well be thought of as turn to stbd by those who don't recall the details of the rules, but that might be no bad thing in the case of entering the fairway that you describe, if your entry involves a turn to starboardThe available range of sound signals under the IRPCS is very limited. There is no cancellation signal, but neither are any limits set for a minimum range of indicated manoeuvre. But if you made a signal say one short blast indicating a turn to stbd say in a head to head situation then did not carry out your maneouvre expect to be found the most guilty party in any subsequent enquiry should a collision then occur.
However, the IRPCS do allow use of non standard signals say to grab attention, Rule 36. Rule 32 sets out that a short blast is approx 1 second long, so for instance a quick toot to your mate as you pass by, or to get someone's attention, e.g. As you enter a fairway from a side channel where boats approaching from port sometimes think they are on a public road do not realise they are obliged to keep clear, and should therefore be keeping close lookout.
I thought you were going to tell us the right answer. If this is a suggestion box, then I suggest ........ as used in Morse.
Yes, eight of them, as you quotedIf I recall correctly. The morse signal for an error is a series of rapid E's.
