stuartwineberg
Weird one this. My heads sink and shower drain share a skin fitting. Whilst doing the usual regular working of the valve it failed in the shut position. I took the stem out (the thing that connects the handle to the ball) and discovered a mangled pink, dezincified mess - the stem had essentially dissolved. What is weird is that the rest of the unit appears to be CR and having scraped it all over is showing no signs of pink anywhere. OK thinks I, the main thing is to open the valve, I'll borrow the handle and stem off another valve on the boat. I now discover that it is slightly different to all the other valves on the boat so has been replaced at some stage. What I need is a new stem with a square lug on it that will engage with the ball and allow me to open the valve and use it for the rest of the season - access is not great as usual - thoughts please? Has anyone come across CR valves with cr*ppy brass stem?
