stav
Hi All,
Have found a couple of leaks in my over complicated water system and want to make a neater installation and cure/find the leak! I have followed and identified a lot of the pipes and valves. But at the moment one piece is evading identification and it is the aluminium rectangular block in the bottom of the hole. It has two pipes coming in and a pipe coming off to a valve to drain water and has a large screw in one side which I have not touched. My thoughts are that it is a sort of one way valve for the drain off's from both water tanks? But on uncovering the front water tank I found it had a separate drain off fitted.
The boat is an early westerly conway.
Thanks in advance.
Thanks in advance.
