burgundyben
I was just wondering, say a biggish containership, 10000 TEU broke down, prop fell off, so its drifting about, a passing oil tanker, big one, could it take the containership in tow?
No. The job requires specialist equipment and expertise such as Smit Salvage is able to provide world-wide.
The tanker's owners wouldn't appreciate its master trying: risking his ship and delaying his Voyage.
I have been on ships that have emergency towing wires assembled and ready to be deployed = but these are just the bridles for the towing line to be attached to.
Ships should (but often don't) have the SWL of the mooring bollards welded / inscribed on them and a cruise ship might typically have bollards that can take 150+ tonnes.
But as noted above, they do not generally have very long lengths of very strong towing hawser type ropes on board, and it would probably be difficult to cobble together something from mooring warps.
@Kukri manages container ships, and I am sure that he has some thoughts on the subject.
I like to watch the series of UK TV programmes about RNLI rescues. They sometimes tow moderately large ships, and tow lines break. I don't remember them saying how they cope with I presume how the two broken ends fly towards the vessel to which they are still attached with the stretch energy...
This was in the eastern Med 10/12 years ago.
Its easy to miss the tow 'rope' - one clue was - they were moving so slowly.
Jonathan
If you ever see tugs towing large vessels offshore the tow lines are immensely long . . .
to try to minimise snatch loads . . .
Similarly if we (ie you) were to tow someone a long stretchy line is the way to go.
I still get a shiver when I recall many years ago, on one my earliest cruising trips, we were cautiously and deliberately passing behind a crossing small ship one murky dawn in the middle of the North Sea, when we belatedly saw emerging from the mist behind it some sort of very low and wide floating platform that it was towing. We were just about to pass between the two!
Quite an incentive to get some formal training, and I'll now never forget the basic towing lights.
In the case of a line for towing a ship, it would be difficult to add enough weight to make a difference, and if you did, it would increase the static tension in the line considerably. Think of "swigging" up a halliard by pulling it sideways away from the mast! It's a good idea for small craft, where the breaking strain of the tow line will be of the same order as the displacement of the vessels, but for a ship, where the towing line is proportionally far weaker, you probably don't want to increase the tension any more than necessary.And/or use a good length of chain in the centre of the tow line - either as part of the line itself or suspended from it. This is very effective at minimising snatching. With enough chain the line is never straight. The towing vessel's forward movement lifts the chain's weight, while the sinking chain pulls the towed vessel forwards.
I had a similar experience when crossing the North Sea at night. A vessel approached from the north showing a mass of lights. From memory I think that all I could see was white lights including some scanning around. Our companion boat chose to go ahead as they were in front of us and I altered course to pass astern. It was a good thing that I gave them a wide berth because there was a massive vessel being towed about a mile astern with no lights at all.I still get a shiver when I recall many years ago, on one my earliest cruising trips, we were cautiously and deliberately passing behind a crossing small ship one murky dawn in the middle of the North Sea, when we belatedly saw emerging from the mist behind it some sort of very low and wide floating platform that it was towing. We were just about to pass between the two!
Just for perspective - you could probably lift Capricious, a Moody 31, by two of her mooring lines. Try that with a ship, and see how far you'd get!
