atlowers
Boat just been lifted. Noticed a worn shiny groove on props haft about a centimeter out from the p bracket and cutlass bearing. Also had a bit of rope wrapped around the shaft. Assumed it was this that had caused the wear but thought this excessive. Then noticed a difference in the gap between back of p bracket and the prop when compared with my other engine shaft. Measurements reveal a 13mm difference in length of shaft from stern gland exit point to back of prop. Is it possible for a prop shaft to move forward 13mm and the groove in the shaft is from where the shaft was previously sitting in the cutlass bearing?
Also what effect would this have on the boat. Been in canals for 6 months at tick over speeds and bit concerned about later return to normal cruising.
