justdrifting
Will a planeing hull be capabale of any speed depending on power?
Lets say a Bertram 28 will do 20 knots with a pair of 240 hp engines. If a magic spray is used and the engines put out 1000 hp the drive train and props optimize to maximize the the power to thrust,would that boat then travel at 40 / 60 / 80 knots or more?
On the same stretch of water in the same conditions?
Sailing dingys plane, if you take a 470 under sail it will plane if you put a 100 hp engine sprayed with a magic spray so that it weighed nothing and again was mounted in the best spot the drive train in the perfect configeration how fast could it travel??
When ive been sailing dingys as the speed increases so does the bow wave is it possiable to get over that that it dosent push the hull back?
What is a planeing hull??
Please forum thank you
