Jamesuk
Can 24v at 355 amps kill you too?
Whats the rule vs volts and amps. I appreciate amps does the killing
I've been taught that under normal circumstances voltages below 48 Volt are safe to touch. Your body resistance is too high to to get any decent current going.
That doesn't mean you cannot suffer burns from sparking contacts or connection points with bad conductivity.
Just my 2cents
The USA use 110v because that is regarded as reasonably safe under normal circumstances. 24v is way under that so will definitely not create sufficient current.
Richard
But electricity wil take the path of least resistance, and 330 amps at 48 volts R = 0.15 ohms. Putting yourself across this load effectively providing a parallel path will see virtually nil current flow through you.
110 volts can be lethal, though the risk of fatality is not as great as a 240 volt shock. I have survived two 240 volt shocks which was down to luck and dry conditions. Where the US system scores is on 240 volt appliances such as cookers and air conditioners because they are powered by a single split phase system whereby each hot leg of the circuit is at 120 volts to neutral (or earth) and 240 volts to each other. That means that if you contact one of the live wires and are earthed, you receive a 120 volt shock, not 240 volts.
24 volts will not drive a high enough current through you to be fatal ....... a few hundred μA only in normal circumstances perhaps.
... I have survived two 240 volt shocks...
The existence of any other path makes no difference at all: 48V will push the same current through you no matter what it's doing as well.
Would you care to review that statement? I'm worried my shunt ammeter might read this and stop working!
If you are silly enough to connect your ammeter across a 48volt supply it'll stop working ! If you are lucky it'll blow its own fuse , otherwise it will be toast.
