cynthia
Merve is in Greece working on getting the boat ready for the summer. One unexpected job is the replacement of the hot water exchange unit, so this is his question:
I'm in the process of replacing the domestic hot water calorifier on my 2001 Bavaria 34. The one I have taken out (original equipment fit - make unknown) has the outlet for the pressure relief valve plumbed back into the freshwater tank. The instructions for the replacement unit I'm fitting (Isotherm SLIM 15) states that the outlet from the pressure relief valve should be left open and unobstructed (stating that it should not drain into seacock or even a skin fitting) it also states that some water will always be present at this outlet in normal operation. I like the original Bavaria solution rather than having to drain water into the bilges. Are Isotherm just being overcautious here or I am I missing a trick ? ie can I plumb the new unit in the same manner as the original Bavaria one ? The only difference appears to be that the Bav pressure relief valve operated at 4bar and the Isotherm one not until 7bar.
Your help, as always, is much appreciated!
