Oily Rag
My Beta has the usual connections to the calorifier to produce hot water. But the engine is slightly above the calorifier, so when the engine is shut down, the calorifier sends a reverse flow to the engine. It keeps it lukewarm overnight but leaves the water rather tepid in the morning.
Can anyone recommend a spring loaded non return valve for fitting into the pipe work from the engine? I'm thinking of something from a plumbers merchant that could be fitted to 16mm/5/8" heater hose.
