Piddy
I have a new-ish 40 litre calorifier under my cockpit locker floor which is heated either by running the engine or using mains. Both work well and produce lots of hot water.
However when not attached to mains, even if the hot water isn't used the water temperature drops dramatically overnight to a point where it's no use for anything.
What I noticed for the first time this last weekend (whilst plugged in) is that the hot water is keeping the engine hot 24hrs after the engine was run it was noticeably hot to the touch. No problem when plugged in but I suspect it's somehow transferring the heat from the caloriifer to the engine through the coolant pipes that connect the two.
This isn't the case on other boats (I have friends that have enough hot water to shower the next day).
Is there a valve I should have fitted or should the pipes follow a particular route to/from the engine to the calorifier. I have found internet sites that mention thermal loss but I wonder if anyone has had any success at this? I do have a non return valve to stop cold water entering the hot outlet pipe but that's it.
Thanks in advance.... Mrs Piddy will be delighted if I can fix this one....
