LeonF
This re-commission seems to be going on for ever !! Tracked down the water in the lockers to a leaking water tank duly replaced today. Ran the engine for an hour.. no hot water.. ran it some more...still none ..
Checked coolant....hot, but tank not pressurised.. was easy to open the filler cap. Water was running freely from heads and sink tap, just not hot at all. I never drained down the tank over winter... discovered there is a lever to do it today!! When I depressed it water spurted out, so guess there is no air lock ??? Suggestion have been that there is an air lock, the water pump is not working properly, or the thermostat has failed, not allowing the coolant to circulate. I have not drained and refilled the coolant , this was next on the list to be done. It is a small rectangular Nautic.
