Cabin top halyard winches - what size?
Windway
Active Member
25 Aug 2012
Porthmadog
I am going to fit the Barton single line reefing system to my Westerly Centaur this summer bringing all lines aft to the cockpit. I can see how to do this and what is required in the way of fittings. I am now wondering what type and size of halyard winch I will require and if self tailing is needed or not? Will one suffice or should I fit two? The mainsail on the Centaur is only 166.75 sq ft. I will have two slab reefs initially. Lines will be 8mm. Clutches might be Spinlock XAS or Barton. I wonder if the Barton single speed winches would do the job hauling in the reefing lines, topping lift, kicker and main halyard, or should I consider a self tailing winch like the Harken 15ST or is this overkill for a 26 foot boat. Any thoughts, or information on how you set up your sub 30 foot cruising boat would be most welcome.
I use Lewmar no8 single speed for that task. One for reefing lines and kicker and one for main and topping lift. ST would be a luxury, and not needed for the power.
We had Harken 8s on the coach roof when we bought the boat (30 ft big rig) and these were standard fit. They were non ST and worked OK providing I was using them not SWMBO. ST winches do make a big difference so in your position I'd consider single-speed ST 16s a reasonable upgrade. We actually upgraded to 35.2 twin speed Harkens all round- way more than necessary but SWMBO wanted twin speed and you can't really have too much power- they just get nicer and nicer to use :) way overkill for what you're doing though.
I have Lewmar 16 ST on my 34 footer. The process of winching can be quite awkward at times, such as when reefing, when you might be needing a hand to brace yourself, and I would suggest that self-tailing is a worthwile addition. I don't think it ever pays to skimp on fitting out, though an 8 would be perfectly adequate for a Centaur in terms of power. I think it is going to be difficult to arrange for winch access to all your lines with only one winch. These winches don't get a lot of wear compared to sheet winches, and will be a good long-term investment.
