vas
cabin floor construction / bilge layout / watertight compartments & other thoughts
Planning my next moves regarding the rebuilt and I'm getting close to the point where I'll have to:
Now, the first two bits are dead easy, I've done enough dismantling already, not much of a prob
item 3 & 4 should be interesting but doable and rather rewarding after a year of knocking things down in MiToS.
However, I've got a few things I'm puzzled with and I'd like your opinion. Rather than mixing them with the original rebuilt thread, I decided to start this one instead. So, bear with me:
1st. do I need/can I have watertight compartments in a ply_on_iroco hull 43ft tub?
It doesn't seem to have any from the factory (will be absolutely certain when I remove the cabin flooring as there may be something on the engine room to cabin bulkhead). But even so, it would only cover engine vs lower cabins so don't know if it really counts.
2nd I count v.highly the ability to have GOOD/EASY/QUICK access to the hull from inside. Especially below the waterline. The above water bits are also important to check for any deck/superstructure leaks capable of doing serious rot damage from the inside out (as I've found in a few places...)
Hence the idea of having cabin flooring extending to almost the edge of the hull (obviously without sealing and creating a watertight area) is plain stupid to me. I'd much rather have flooring where I need it and be able to lift the bed underdeck to have easy access to the hull if needed. Further I'd have much larger storage space as a result!
Am I missing something? I don't think so, but open to suggestions. Don't mention rigidity as this can be obtained in many different ways and anyway the current flooring is a bit squeeky at places and I have to make a better job on that.
I could guess that sound insulation (water flapping sort of thing not engine noise...) would be better but again I doubt it and I could improve things dramatically with proper cabin lining and smart use of ricofon panels.
What else?
The following pic shows how the 2nd cabin floor is organised. Where the carpet ends the bed starts, but flooring UNDER the bed??? why?
The second pic is the stbrd side with everything removed (but not cleaned-it's even worse right now
Regarding bilges, the iroco frames every 300-400mm are good for structural stability but awkward as far as managing bilge waters.
Cannot possibly have 30bilge pumps one on each section to be able to empty the lot so atm have to resort to evaporation due to heat for that
I can see there are some through section holes in places and I wonder if it would be acceptable to have just above the keel limber holes on the frame to let the water move and be extracted from wherever the bilge pump is... Seems that this is happening on a few framess but not all.
Planning to have 3 bilge pumps (all auto) one in the lazzarette, one in the e/r and one on the corridor to the cabins. Ideas?
I've not described the things v.clearly I'm afraid so i'll come back with clarifications if it's too confusing. Need to take a few more pics as well of the bilges.
cheers
V.
- remove all cabin flooring and supporting beams
- remove one more bulkhead (have already removed a couple more)
- find ways of fixing 2 new bulkheads for the two heads SLANTED in plan hence not aligned to the iroco frames
- start the rebuilt of the cabins (floor upwards)
What else?
cheers
V.
