john_travers
Need new sails for a Fulmar. Main & Roller reefing Genoa for cruising. Have got quotes from various sailmakers with sailcloth samples. Difference in price so far cheapest to most expensive over £300. Sailcloth samples show weights presumably in oz/yd. The most expensive appears to be the lightest weight but is a material I have heard of. Dimension Polyant. Is it the case of "you get what you pay for" . i.e. Cheap sails use cheap material . I was also told by an old salt "dont bother with biradial & foam luff". If you need to roll it away you are probably up to hull speed anyway. Just accept you might heel a bit more and not point as high.
All advice gratefully received.
