buying boat in uk with jersey registration
johns
31 May 2001
renfrewshire
hi there i am hoping to purchase a second hand boat the problem is the boat has been registered in jersey would this mean any implactions or cost once i have purchased the boat
jfm
Jersey/Antibes
Assuming you want to re-reg in UK (advisable) then you need a deletion cetificate from the Jsy registry. Normal to request seller to sort this out, and he is then required to deliver boat and deletion certificate on completion of transaction (ie the day you pay and take possession).
Then you can reg in UK, and send them the deletion cert, as they will require that.
As mentioned, it is likely not VAT paid if Jersey. So you'll be obliged to pay VAT on import to UK.
Though there may be solutions to that if it's a big/expensive boat. Also are you buying privately or through a dealer, as that has a vAT impact?
doug748
1 Oct 2002
UK. South West.
In my experience you should have few problems with the registration. Transfer the ownership in the usual way and keep it that way. The boat may have been kept in the Uk anyway......the VAT problem and EU directive are another matter, as already pointed out.
AuntyRinum
30 Jul 2003
Travelling
I have a Jersey registered boat which I bought in Hampshire and keep in Brighton. There are no problems with it at all. Just inform Jersey registrar of the change of ownership in the usual way.
BarryT
22 Aug 2001
Dover
Brett
It was my understanding that you have to have a local representative if you are not a Jersey resident. Is this what you have done ?
AuntyRinum
30 Jul 2003
Travelling
No, not true. It's just part of the British Registry. You complete the normal forms as you would in UK. You can do it by post, as I did.
Phone the Registrar at Jersey Harbours and they'll confirm that I'm sure.
Address and phone:
Jersey Harbours
Maritime House
La Route du Port Elizabeth
St Helier
Jersey
C I
JE1 1HB
Tel: 01534 885536
