Buying a 17 foot Bowrider? A couple of Questions
David_Jersey
22 Dec 2004
Last year I was thinking of also buying a cheap dory, this year I am thinking of instead going for a Bow rider (around 17 foot with an outboard), the reason for the change in thinking is that I could not get myself comfortable with knowing that the foam core of a dory would not be / would not get waterlogged, plus it would be nice to also have a windscreen at least now and again.
As a sailing and mainly displacement motor boat bloke I realise I have never been above around 15 knots on the water!…………so I have a couple of questions.
I realise that the bulk of the boats value will be in the outboard, as I am buying secondhand (very!) I am mulling over the idea of buying something without an engine and then buying either a new one or a s/h one that I know is good – on the basis that although it will work out more expensive than buying a package s/h I will at least know what I am getting and as I intend to hang onto the boat for many years as a 2nd / occasional boat (I still have the sailing boat!) I will get the use out of the Engine. It would also mean I would definitely have a 4 stroke which I would prefer for fuel economy / range which = less frequent fillups!
It appears from my research that 17 foot speedboats come with Engines of around 100 /125 hp – my question is what sort of performance will I be missing out on by dropping to a 75hp (or less?) 4 stroke. I am not interested in wakeboarding or waterskiing, maybe towing the odd small donut. I would like to be able to cruise at around 25/30 knots, so outright speed is not a factor nor is acceleration. I am unsure as to whether on a small speedboat having loads of extra power on tap has any safety benefits?
Regarding the open bow bit, I see that they have covers, I presume that in practice that they keep the spray out (more or less) and help to guide the odd “dollop” over the bow and away from the inside, and in practice having an open bow with a cover on a 17 foot speedboat is not much different from having a solid bow on the same craft in that I figure that if solid waves are big enough to be breaking over either sort of bow then I am in the wrong boat anyway! Please let me know if you think I am wrong on this thinking. I see it as an open boat with a windscreen attached.
Just for info the Boat will mainly be used for occasional whizzing around the bay, anchoring up in nearby bays for the afternoon for a kip, a swim and a beer and also maybe as a launch base for a couple of inflatable Kayaks. Maybe even some scuba diving, if I can get my head around cold water diving! Also for the very occasional trip across to France (Town / Gorey to Portbail on a good day) and a few trips to the Ecrehous, all on a good day – (and I do have safety gear coming out of my ears!).
Whilst I am here, does anyone have any links to folk who do covers / camper covers for Bow riders? I am talking off the shelf rather than hand made – if it is the case that a certain model ie a Bayliner xxxx has these available “off the shelf” and another model does not then I would go for the Bayliner.
BTW something like a 17 Bayliner Capri would be the sort of thing. But really not that fussed, they all seem much the same to me and my choice will no doubt be down purely to availability.
engine size wise two trains of thought. Will you use the full power of 100/125 horses or more likely how often will you have the conditions to use it all. Smaller engine will work harder for the same speeds. saying that a light 17 footer with 70 horses won't be a slouch.
For my money I'd go for a decent late secondhand pakage with service history. You'll probably get a few "toys" and gear thrown in with the price.
Bow riders are wet. Bow covers a good idea but off the shelf ones will probably be from the manfacturer/dealer at dealer prices. Searay did do a bowrider that had a solid grp bow cover. Best of both worlds.
You will always get the odd "solid one " over the bow , even in fairly calm conditions, overfalls , large wakes from ships/tugs , semi displacement cruisers around 35 ft at speed leave an evil wake, I would go for a solid bow/cuddy if possible.
I was doing an own boat level 2 coastal assesment for a chap with a bow rider and he had his cover in place...that is until we dropped into a hole caused by overfalls. This one rogue sort of wave rather than a whole mess of overfalls. The bow buried itself and the weight of water popped all the fasteners so none of the cold green (or actually brown as it was the Bristol Channel) stuff went overboard it all came in.
We suddenly had a freeboard of about 3 inches.
Upshot of all this was a tow into Portishead by the lifeboat.
The owner has now had made a fibreglass in fill for the front section.
If you intend using it on the sea get something that sheds water and doesn't act like a giant scoop, relying on canvas covers with press studs doesn't work.
Cheers folks. Can't beat first hand experiance.
The open bow does seem a bit unnatural for me - but I want it just for a bit of extra lounging room / extra space / ease of line handling on a small boat - a solid deck 24/7 is never going to provide much extra space that is much use for me - the boat is principally going to used for whizzing around the bay / nearby all with 20 minutes of "home".
But a solid cover does seem the way to go, especially "cross channel" /forums/images/graemlins/grin.gif Will have a looksee what makes have one available.
Just for info the trip from Jersey to nearest France is about 15 miles (you can see it on a good day), so for the occassional trips I am thinking off this is less than an hour each way at the speeds I am looking for. Done the trip a million times since I was 2 foot tall, know enough to be aware of what the trip can involve - as long as you keep an eye on the weather small stuff is no real problem, sometimes uncomfortable - but "safe" enough. Actually more "worried" about any trip around the coast from Town to Gorey - which I have done far less - which I actually need to navigate each time - thinking is so much easier at 7/8 knots!!
BTW the Ecrehous is half way. Used to work with folks who would visit with their Jetskis on a weekend, they always came back to work on a Monday - but still NOT something I would fancy. /forums/images/graemlins/laugh.gif
I Had a Fletcher Arrowsport 17ft bow rider - that had a fibreglass panel you could lock in place over the bow. Bit heavy though - you had to make up your mind if you wanted it or not prior to launch, as you couldnt easily remove it once at sea. But a great alternative to the bayliner.
Martyn
Hi David - my last boat was a Shakespeare 17 foot bowrider with a 100HP Suzuki. The Suzuki was new and replaced the aging but excellent 90HP Merc. Inspect the hull for dings, and inspect the floor - make sure it hasn't gone rotten with age.
My family of 5 had two years of great fun in it, but it is an inshore boat. You would need a very calm and settled day to make the crossing. 75HP would be OK providing there aren't more that 3 people in it. Fit a bilge pump - a good one! Carry a spare small outboard - a boat without an engine is no more than a raft. Carry a VHF radio and a handheld GPS (or fixed depending on budget).
Buying the boat and trailer and then seeking out a good motor is quite a good way of doing things. My previous two boats were bought this way. Yamaha and Suzuki are generally respected as being the most reliable and bomb proof if you are buying second hand.
Good luck.
Dave_Snelson
[/ QUOTE ] - on my list!
[/ QUOTE ] - got these already, plus plenty of other kit either spare or on the yacht.
[/ QUOTE ] - not had a chance yet to closely inspect any bowriders, but as you say, it probably makes sense to make the Bilge pump "a good one", even if one is on board already. Cheers.
Glad someone else has been down this road. My thinking is that a boat of this type and this size, say over 10 years old, is pretty much unsaleable without an engine - unless it is very cheap (and I like cheap! - especially as I am not bothered about the latest looks or even resale value - I want the money spent to be as much as possible on the motor). But I want to avoid buying a package that has been "cobbled together". The hull itself does not worry me too much, but I want to avoid buying "someone elses problems" with the Engine. I could swallow buying a new Engine (or would wait for a good s/h one to turn up - with a solid service history and checked out by a local enginer) because I would be using it for years but I wouldn't want to do so after having bought (and paid for!) a duff engine already!
[/ QUOTE ] I am not totally familiar with the construction of small speedboats - by "rotten" do you mean wet and delaminated fibreglass or are we back to a foam core that also provides hull rigidity in addition to bouyancy?
well, dont freak about bowriders, or ban them bcz of some comments here. It just depends what you are going to use the boat for. If you envisage your boating being where waves (or wash i might add) are going to break over the boat, maybe you want something bigger than 17ft anyway. If you are just going to use it as a fun dayboat for wizzing about the bay inshore in good conditions,waterskiing etc, then I d agree with your first thought.. the extra room up front is good, and its easy jumping ashore etc. You do get 30pct more usuable boat for this kind of boating. But, anything a bit "offshore", i think a small bwrider isnt the job.
