Busted Eberspacher
Nick_H
20 Apr 2004
www.ybw-boatsforsale.com
I accidently turned off the boats 12v yesterday while the eberspacher was still running, and even though I remembered immediately and turned it back on, it seems i've bust it. The fan is still running, but i'm just getting thick, light grey smoke coming out of the exhaust, which I assume is unburnt atomised fuel.
Any ideas?
Any ideas?
Should be wired direct to battery through it's own fuse, NOT through the isolator switch for this very reason.
Don't know which model it is,some will start up eventually, modern ones should give a diagnostic code.
If it does start, give it a good hot run then rewire it properly.
