isandell
I have just dismantled raw water pump on Bukh DV20 ready to replace lip seals. This is an old style pump with plain shaft bearing.
Between the two seals are two stainless washers, ID about 1mm more than shaft dia, OD about 0.5mm less than lip seal od, thickness of each is about 1.5mm.
My manual shows an O-ring rather than washers. Any ideas about which is correct?
I would like to get the pump assembled and fitted before Tuesday, otherwise I would have rung Bukh.
(Previous owner was a bit of a bodger).
Ian
Ian
