Bukh oil leak
Matador
28 Feb 2006
Cornwall England
Hello All, at the end of last season after a short period of hard running our trusty DV10 started leaking oil. The leak is at the front of the engine but is difficult tp pinpoint because of the flywheel. My immediate thought is the sump gasket, which would mean lifting it out !@£$^! Any thoughts? Cheers, Chris W S26 Chablis.
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
The most likely engine oil leak on a BUKH is from the rear outlet shaft seal. Easy to replace......once you have removed the gearbox!!. This is a task I need to do on the BUKH20 in my Sadler29. It should be just about possible to remove the geabox in situ after releasing the engine mounts and raising the rear of the engine.
I don't think there is sufficient access to do this on the S26, so I fear it would be an engine-out job. The front seal is of course also a possible cause, and IFF you can get the flywheel off in situ might be possible - no experience!
Vic 'SUNDASH' Sadler29
clyst
18 Aug 2002
Rusted oil feed pipe . check it out at the front of engine behind the flywheel .
cimo
11 Nov 2009
I'm considering changing my thinking on oil leaks. Lately I'm telling myself they are nothing more than reassuring health signals from a happy running engine! Signs of life if you will.
my 20 is currently leaking from the lower oil pump mounting stud and there's lesser leak at the fuel lift pump gasket. The gearbox is leaking at the front shaft seal. All my leaks eventually make their way forward to the front of the oil bilge. (I'm very close now to being able to justify that engine lift out).
Make a thorough inspection all round with a mirror, and start a list is probably the most useful advice I would give.
(removing the flywheel is straightforward enough - there are things you should be aware of when replacing it though - shout if you need the workshop manual).
Matador
28 Feb 2006
Cornwall England
Thankyou one and all for the advice. Obviously I need to have a proper look. This is the latest problem I have had with the dear old Bukh (actually it's only 11 years old). After a new exhaust, starter, injector refurbish, I was wondering what was going to be next. It's not like it has a hard life or anything.That new Beta looks more and more enticing! Cheers, Chris W S 26 Chablis.
bluenun
13 Oct 2010
had the same trouble with my bukh,, found it had polished bores and was pressurising the crankcase,, fumes coming out og oil filler cap when running,( these fumes are not good for your health ) a fresh set of rings and de glaze the bore and it was sorted ,,
Bat21
9 May 2005
Another Planet
At the risk of repeating myself:), sudden unexplained oil leak from a Bukh, first check and clean the Vacuum valve on the crankcase breather. This saves a lot of speculation and expensive fafing about!
Babylon
7 Jan 2008
Solent
A year and a half ago my old DV20 had a similar leak, which got worse and worse. It WAS the front seal, and the 30-year old engine had all sorts of other issues which ultimately required a proper re-build, but in the end I fitted a new Beta 24.
However, an 11-year old engine shouldn't need replacing. Get it properly checked, or do it yourself if you have the knowledge. Bukh can supply a full workshop manual and removing the flywheel is no big deal.
BTW a 'short period of hard running' shouldn't hurt the engine. Had it been neglected beforehand?
