April's keeper
New Member
Oil capacity 0.5l, as stamped on id plate. I have filled the box with 0.5l of engine oil and get the correct reading on the dipstick, however when the output shaft has turned and I read the dipstick it shows massively overfilled. It is only when BOTH dipstick and filler plug are undone does the oil level go back to the correct indication. This is fine as the gearbox is on the bench. It is not fine when the gearbox is back in the boat. The pressure relief valve on the rear of the box is not blocked but the spring is holding the rubber pad against the vent nipple. Does anyone know what is going on?
