blackfish
Further to my battery charging issues (on another thread) can anyone tell me the 'must know' gen about the internal charging alternator on this engine?
Thanks in advance.
Thanks in advance.
Looks like a stator coil assembly under the flywheel with a 3 phase output to a rectifier/regulator.
Pretty much like many outboards.
Thanks for that. Looking at the Bukh spares catalogue, it is described as a 'charging alternator 210W'. Any ideas what that refers to. I'm assuming it's a wattage output. Aren't we more interested in amperage? Is there an equivalence relationship between the two?
Pete has explained the relationshipThanks for that. Looking at the Bukh spares catalogue, it is described as a 'charging alternator 210W'. Any ideas what that refers to. I'm assuming it's a wattage output. Aren't we more interested in amperage? Is there an equivalence relationship between the two?
You might fnd the Boat electrical course notes at http://www.tb-training.co.uk/ useful in acquiring some basic electrical knowledge.
View attachment 57665View attachment 57664
OK Hive Mind, if you can help further I'd be grateful. Went to the boat this afternoon. Both batteries show about 12.6 V on the meter, whether the engine is spinning or not. So, safe to assume that they are not being charged. The Bukh DV8 has an internal stator-type alternator, behind the flywheel. Three wires emerge from the casing behind the flywheel assembly and run to a finned (heat dissipating) contraption bolted to the back of the engine block. Looking at the parts manual, this seems to be what Bukh describe as the charging regulator. The three wires attach to the regulator unit by spade connectors. Out of the top of the regulator a number of wires emerge which are connected to a wiring loom by means of a plug connection. I have included above a photo of my actual set-up and a shot of the Bukh spares manual diagram.
So my questions are these.
Is there any useful information I can glean by using a multimeter on the three 'input' wires? Will that tell me whether the stator alternator is working?
Is there any useful information I can glean from a multimeter on the 'output' wires from the charging regulator?
I am assuming that if they are both working correctly, then my problem lies somewhere further downstream amongst the spaghetti-fest of the wiring.
I don't know whether my photo is reproduced in enough detail here, but a close inspection reveals some hieroglyphics stamped onto the rear of the charging regulator.
Grateful for your time.
PS Just to add insult to injury, I'm pretty certain that, if it were necessary in order to get to the stator, there is insufficient clearance to remove the flywheel (because of its proximity to a bulkhead) without lifting the engine from its mounts! Heigh ho!
Just a quick question: why does the positive go via the starter motor solenoid rather than directly to the battery?
As Pete says its just a convenient way or wiring things up. The main heavy + lead from the battery goes to the starter solenoid and that makes a handy nearby place to connect the alternator output.
