Timsuttle
Active Member
Hi does anyone know of someone that could service my Bukh dv20 in the Weymouth area?
Tim
Tim
Thank you.Oil change
New oil filter - Halfords HOF200
New pencil anode
Wipe over and check for oil/fuel leaks
Check soundness of electrical wires
New water pump impeller (every other year)
New Fuel filter (every other year)
Thank you.They are very common, and straightforward, uncomplicated engines. Almost any marine engineer would be familiar with them, and be able to service it for you.
It is a straightforward task to do yourself, as others have said, and if you don't have the confidence to do it now, it would be good to find an engineer or someone else to show you what's involved so you will be armed next time, or if something goes wrong while you are at sea.
I would add to neil s's list -
Particularly check (1) that the tell-tale holes behind the seawater pump are not blocked, and (2) whether there is any water leaking from them (in which case replace the pump shaft seals a.s.a.p., to avoid serious damage to your engine).
Check condition and tightness of alternator (etc.) belt(s)
Check for exhaust or water leaks.
