Bukh DV20 Madness!
unclebraddah
Active Member
9 Jan 2008
I posted this on other forums But I am aware many of Narrow Boaters use this engine so I am posting it her as well as I am desperate. A letter to Bukh.
Hello. I have a Bukh DV20 built in 1973. I am sorry I dont have engine # but I hope they are fairly standard. My engine starts, and just before reaching normal RPM's dies. It will keep puttering if I keep the starter going.
It happenened all of a sudden. I needed to put a new valve cover gasket on because it was leaking oil. A minor maintenance issue. Of course I thought air in the fuel so I put a clear return line off the filter bowl back to the tank. yes there is air.
I have cleaned the lift pump and removed that little filter, It seems to be pumping fine.
I have replaced the Filter Bowl filter and seal and even tried running it without it. No change.
I have resealed Banjo fittings.
I have completly taken apart and put back together the Injector pump.
I replaced the high pressure lines from Injector pump to injector.
I have cleaned and inspected and retorqued injectors.
I loosened the rear High Pressure(HP) line and it kept running(with starter help)
I loosened the front HP line and it stopped.
I switched injectors and it remains that if the front HP line is loosened the engine stops dead.
I hooked up an electric fuel pump directly to the filter bowl from a supply above the bowl.
I Checked the Manual Govenor Spring wire to make sure it was caught in it's proper holes. It is but there is no response or acceleration if the shaft is turned, yet there is a return.
So...today I will check the Valve vacum system above the vales and am getting ready to tackle inspecting the centrifugal govenor.
But I feel it is something simpler having to do with me changing the valve cover gasket. Did I not adjust the compression lever proper? If so did I do valve damage? Everything looks OK. I have compression.
I really like this engine but it has been down since April. Im getting so frustrated I am looking at other engines infourtuantly. All the forums say to call you guys. It is a 12 hour time difference as I am in Hawai'i. So it is difficult and I want to make sure I have the right answers to any questions you might have.
You're thoughts are appreciated.
Thank You,
/forums/images/graemlins/laugh.gif /forums/images/graemlins/smirk.gif
