micha571
I have a problem with a Bukh DV 10 LSME (Saildrive).
The mechanic which wanted to drain the cooling water turned on a screw which he thought to be the drain plug.
It was not, it was the “excentric for full-load stop”, screw no. 43 in the attached picture. He did not remove the screw completely, only turned it out by some turns, then turned it back in.
Afterwards, the engine was running, but did not rev up when moving the throttle lever. I turned the screw about ½ turn further, now it is revving up again, but has lost idle speed.
So I am sure nothing is broken or wrong, but I guess the screw has to be adjusted correctly again. Does anyone have an idea how to adjust this properly? I studied the explosion view (attached picture) for hours, but just don’t understand what this screw exactly does.
Any help greatly appreciated….
Regards, Michael
Regards, Michael
